konica press c7000 with ic-601 electrical problem
  • akoam
    • Jul 2025
    [Electrical] konica press c7000 with ic-601 electrical problem
    Hi all
    i have a problem with my konica c7000 controller .
    - the printer work fine as a copy machine
    - if i connect the controller to the printer then turned then turned the printer on , the controller power cable Burns directly
    - The problem occurs only when the controller is connected to the printer
    what i do to check :
    - checking the voltage in the socket its 220 V / 50HZ
    - replacing power supply (Did not solve the problem)
    can anyone help please .
  • princef18
    • Jul 2011
    • 37
    Re: konica press c7000 with ic-601 electrical problem
    Check the earthing in the socket.
    This is a really weird problem. Does it occur if you power on the controller without the interface cable plugged in? Maybe the interface cable is faulty.
    • akoam
      Thanks for your reply . It happen only if i plug the interface cable . Smoke immediately appears from power cable
      • princef18
        • Jul 2011
        • 37
        Check the interface cable, it is probably shorting out somewhere. If possible, try to swap it with a known good interface cable.
        • methogod
          • Dec 2008
          • 920
          does the IC601 run fine when not connected? are you on the right voltage on the new power supply? if you select 120 not 220, you running neutral to a power, and yup ZAP.
          • m_morghm
            • Jul 2019
            • 2
            Thank you all , i sent it to Konica at Malte , the controller mainboard was damaged (burned) , changed all fixed
            Thanks all again.
