I got a used bizhub C450 that always print with image that stretched by about 2mm at the lower right corner. I removed the transfer belt to look for any defects but found none. So I put it back and now the machine prints with the printed area shifts vertically (either up or down) every few pages. If it starts up ok, after a few runs it will print with the printed area shifts down by about 2-3mm, then it's back to normal again. This goes on and does not stabilize even if I print up to 500 pages in a single run. I have tried with different paper size and thickness settings, and did the paper feed adjustment in service mode. Nothing helped. So far I suspect it is either the transfer belt or the transfer roller. Hope someone can shed a light on this. Thanks.
Hank.
Hank.
