KM C6500 and oce CS650 toner
  • brian155
    • Jan 2008
    • 50
    gents, could anyone tell me if the toner for both C6500 and CS650 engines are the same .i.e. that the bottles physically fit rather that the chemical make up. i would like to run both engines but only want to stock one set of consumables.if not then i will change the toner bank completely,any information would be greatful thankyou.
  • DadO
    • Dec 2007
    • 404
    If engine is the same then toner should be compatible.Oce got whole color tehnology from konica minolta even tho i do not understand why did they do that just like that to give a way technology that is god knows how much expensive then techn. of B/W machines.....
    • brian155
      • Jan 2008
      • 50
      many thanks for the reply, i know that both the consumables are the same (i.e.drum and developer) as each other but my problem is will the grooves on the bottles line up to fit into the housing in the toner bank. sorry for not making this clear. oce part number for toner ?
      • DadO
        • Dec 2007
        • 404
        Its on u to try . If bottle isn't fitting then toner surely will : ) but dont take me for granted since i didn't saw oce version of bizhub pro C6500
        • ni311
          • May 2008
          • 658
          If the developer is the same, from my logic, the toner should have the same exactly the same properties. Try to modify the toner bottle or the toner hopper mechanism. In the worst case scenario, just put the toner from one bottle to another.
          I know you want the answer if it's fitting or not but this is all I can help you, sorry
          Konica Minolta Error Codes - Explanations and Solutions
          • Specilist KVN
            • Sep 2008
            • 79
            If the bottle will not fit do NOT force/modify it it.
            Depending on the Machine KM does upgrade their tomer with model upgrades.
            The 6501 uses new toner.
            Seeing as the toner is such an IMPORTANT component of the machine i would not mess with it. You may not get the desired results.
            • ni311
              • May 2008
              • 658
              KVN, if the C6501 is using new toner, how come it is using the same developer as 6500?!
              • kmcopier
                PSP
                • Oct 2008
                • 183
                Toner (OEM)is the same and it fits but trie to get it out CMY (K no problem) you have to cut in the hopper unit a small rib take a torch and you see it
                • Setright
                  FSS / SPM
                  • Nov 2008
                  • 247
                  • random
                    They have only increased the capacity of the toner cartridge.
                    • CS665
                      Service Mode for CS665
                      Does anyone know the keypad sequence to get into service mode on the Oce cs665 or KM C6501
                      • Setright
                        FSS / SPM
                        • Nov 2008
                        • 247
                        Well, yes.
                        Not to be a party-pooper, but I don't know that we should share such information here. Could get into the "wrong" hands.
                        • CS665
                          Thanks anyway
                          Found my cheat sheet
                          FYI
                          Utility
                          stop
                          0
                          0
                          stop
                          0
                          1
                          • Setright
                            FSS / SPM
                            • Nov 2008
                            • 247
                            Admin , maybe this isn't such a smart thing to have posted ?
                            • ni311
                              • May 2008
                              • 658
                              I'm getting scared, you're servicing a C6500 and you don't know how to enter in the service mode.
                              I am wondering what you'll do in the service mode since you didn't know even how to enter in this mode...
