Color Magenta Problem
  • konika_c353
    • Aug 2025
    I've problem with my machine c353, magenta color always out when i print color full ..., any one can help ..., thanks.
    • 14813
    Re: Color Magenta Problem
    Replace the magenta imaging unit.
    • Bix
      • Apr 2018
      • 1421
      Counters?
      Consumable state?
      Regular maintenance?
      OEM Toner?
      OEM Consumables?
      • jwai
        • May 2018
        • 509
        Guess may be the magenta print head unit,
        you can test it by exchange with yellow or cyan one.
        • Anthony mazimum
          • Feb 2019
          • 9
          Replace the developer.
          • allan
            RTFM!!
            • 5462
            Screwy ribbon cable at the back of the machine?
            Whatever
            • konika_c353
              I'll try ..., i though maybe the print head ..., IU already change still like that ...
              • konika_c353
                I'll try ..., thank's
                  Originally posted by Bix
                  Counters?
                  Consumable state?
                  OEM Toner?
                  OEM Consumables?
                  Thanks for covering the usual Q's
                    Printhead/ROS/LASER is more than likely not the issue..
                    someone mentioned Dev unit.. try that path first
                    • Zeldaman
                      • Mar 2011
                      • 946
                      Hi there!
                      Seen this some times on this model. In all cases it was a contact-problem with the springs & contacts of the HV-unit. Check the correct position of the springs & clean the contacts.
                      Greetings...
                      • konika_c353
                        I've changed Imaging Unit ..., but still problem ..., until the developer color became black ..., when i try again .., magenta color not came out ...
                          correct me .. this is NOT an AIO unit..separate drum/toner/dev
                          your example are are dev unit ( IU changed charge roller in IU ) was it OEM or 3rd party?
                          you dev unit SHOULD have strong MAGENTA brush on it.. IF it has NO brush REPLACE..
                          with ALL the back-n-forth on this.. I'm sorry I do not feel you are a quali'd tech on this.
                            • 14813
                            You have to be clearer in your description. What does "until the developer color became black" mean? And what does " magenta color not came out" mean?
                            Maybe post a picture.
                              • 14813
                              On the C353 series the IUs are one piece. Durm and dev all in one.
