Bizhub c454e can not access web browser
  • bratpit
    • Feb 2019
    • 9
    [Misc] Bizhub c454e can not access web browser
    Hello i have a problem. My konica bizhub c454e can not access web browser. I tried several web browsers: chrome, firefox & IE. And also did a clear network data and problem still occurs. The machine CAN print, scan not working and cant access web browser. I also check other router to eliminate network and still no good. Help!
    Print over network - OK
    PING - OK
    Scan - not working
    Access over browser - not working (blank page, waiting to answer from eg. 192.168.0.77 - this is IP my c454e. Computer IP is 192.168.0.122, router IP - 192.168.0.100.
    HTTP server on c454e is ON.
    Any suggestions please?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub c454e can not access web browser
    Firmware updated?
    Try changing IP's or omitting the router.
    Whatever
      PING - OK
      Scan - not working
      1) Scan to what?
      Local server?
      Email? **note known issues with S2E on win10/7 SMB issues - pretty sure on win server
      USB?
      Workstation?
      2) If server: what OS version? Workstation: same.
      3) Does error log show anything related?
      Do they have an IT dept?
      • bratpit
        • Feb 2019
        • 9
        I changed the IP address and the problem is still there.
        The firmware was not updated. Is it newer than the ones I have uploaded?
        2019-02-09 17.25.05_resize.jpg2019-02-09 17.24.55_resize.jpg2019-02-09 17.24.51_resize.jpg
          • 30264
          try changing to https
          • bratpit
            • Feb 2019
            • 9
            1) Scan to what?
            Local server?
            USB?
            Workstation?
            1. Scan to local computer.
            2. OS on computer is windows 10.
            3. How to check error log?
              From service mode.
              Do you know how?
                • 14763
                There is a setting in admin mode that allows PSWC
                • bratpit
                  • Feb 2019
                  • 9
                  From service mode.
                  Do you know how?
                  I do not know. How can I view the logs?
                  • tsbservice
                    Field tech
                    • 8019
                    I would say that also, but in that case OP stated that cannot scan so I'm thinking about HDD.
                    Check in SM or admin mode that HDD isn't Unset or failed.
                    • bratpit
                      • Feb 2019
                      • 9
                      PSWC in settings is ON.
                      • bratpit
                        • Feb 2019
                        • 9
                        In SM HDD is not installed.
                        • tsbservice
                          Field tech
                          • 8019
                          Then go and set HDD in service mode. You may need to format it, movie data, FW etc.
                          Best case it will work once machine recognized it.
                          • bratpit
                            • Feb 2019
                            • 9
                            It looks like I do not have a hard drive installed.
                            • allan
                              RTFM!!
                              • 5462
                              So not HDD in the machine? Mmm wonder where it went.
                              Whatever
