Bizhub 350 BW Default Scan Setting
  • wkwar
    • Jan 2019
    • 61
    Hello All
    Have set up scan One touch to FTP and works fine. However, it defaults to Fine. Can't figure out how to set the default scan resolution to a higher resolution on this machine. Can select it manually every time but we want it to be a default.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub 350 BW Default Scan Setting
    wouldnt you just need to set it then go user settings - scan fax settings then set the defaults from factory to current?
    i never worked on such a old model though so menu might be different
    • wkwar
      • Jan 2019
      • 61
      I don't recall this option is available. will check again with the "Dino" machine. Ha ha
      • jwai
        • May 2018
        • 504
        It seems take the default setting on Web Connection.
        • wkwar
          • Jan 2019
          • 61
          yes it does. thanks
          • rrrohan
            • Sep 2011
            • 1977
            ask the client, im sure they will be "fine" with it
