Tension to transfer belt gear
  • PsYcH
    • Jul 2025
    [Jamming] Tension to transfer belt gear
    Hello, so I have a problem on my minolta C220. One day it started to make some noise, sometimes noise dissapeared, sometimes appeared. For now, it is very noisy, and I found the problem for this, it`s one of the gears in transfer belt. Looks like it doesn`t have enough tension to gear below it. Actually cant understand, why this happens and which part needs to be changed. Belt by itself? Adding video to be more clear.https://vimeo.com/user49447170/revie...656/b8344edf4b
    As you can see, I`ve added some paper to make some tension down, then noise dissapears, when i remove it, noise appears again.
  • Bix
    • Apr 2018
    • 1421
    Re: Tension to transfer belt gear
    Hi, open the transfer belt cleaning brush and make sure it is not clogged with toner.
    They should be two or three screws.
    • allan
      RTFM!!
      • 5462
      Here is a recent thread about this.
      Bizhub C280 noise
      Whatever
