service code c-2227 on konica c11000 pro black machine
  • BOTOY
    • May 2016
    • 46
    Hi guy,
    I opened imaging unit on my konica c1100 B/W machine to remove jam paper entered cleaning blade.
    When i restart machine. I had service code C-2227 appear!
    I check if i forget any connection or part, nothing.
    An idea please?
    Re: service code c-2227 on konica c11000 pro black machine
    Originally posted by BOTOY
    Hi guy, I opened imaging unit on my konica c1100 B/W machine to remove jam paper entered cleaning blade.
    An idea please? Thanks
    what does your service manual say is the root of the code?
    • allan
      RTFM!!
      • 5462
      Wow the C11000 limited by the size of the truck delivering the paper?
      Had to make a joke.
      Google is your friend.
      Whatever
      • Discount Printing Service
        • Mar 2009
        • 36
        does the imaging unit have chips?
        Thanks,
        John M
        DPS
        Senior Field Technician
          Pretty sure the SM would have that info.
          • BOTOY
            • May 2016
            • 46
            Had to make a joke.
            I'm sorry, it is KM bizhub c1100 pro B/W machine.
            • BOTOY
              • May 2016
              • 46
              Hi,
              Finally it was developper unit motor blocked.
              I fixed it just buy removing some developper from unit.
              • allan
                RTFM!!
                • 5462
                Hi,
                Hey thanks for your solution.
                When you post add the description of the error code.
                And stuff you have tried.
                Then the guys will warm up to you a bit more.
                Whatever
