C284e
  • Gina82
    • Oct 2017
    • 98
    C284e
    I have a C284e that has SD-511 in the finisher. My problem is when paper reaches finisher to be center folded and stapled, the first saddle staple cartridge leaves an indention where the staple is supposed to be but does not put a staple through the paper, the second saddle staple cartridge does however place the a staple through the center of the paper like it is supposed to. A tech before me replaced the first staple cartridge (A10DP00100) and the copier functioned properly for maybe a month and now the machine is back to doing the problem described. I've checked the service manual on the machine and there is no mention of this problem.
  • allan
    RTFM!!
    • 5462
    Re: C284e
    You need a jig to replace the staplers on these?
    Whatever
    • tech51
      • 846
      Re: C284e
      Swap the two cartridges around to see if the fault transfers over. If it does then re seat the clear staple holder (the piece with the staples in) in the affected cartridge.
      Ive seen a few of these not located properly which eventually causes the staples to misfeed.
      • Gina82
        • Oct 2017
        • 98
        Re: C284e
        Went to check the machine today and attempt to swap staple cartridges but the machine was fully functional. This happened before though, we replaced the staple cartridge and the machine functioned fine for a while but after a while the same problem occurred. Any idea of what might be happening?
        • guitar9199
          • Sep 2016
          • 1100
          Re: C284e
          Gremlins?
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Re: C284e
            Had one do this recently. Swapped the cartridges around, with no change. Had to be a problem with the clincher in the SD, unfortunately the stapler unit is non repairable and no parts are made for it so you have to replace the entire stapler unit. I tried to order a new stapler unit, but the company didn't want to spend the money and we swapped out the finisher instead.
            • Gina82
              • Oct 2017
              • 98
              Re: C284e
              Originally posted by guitar9199
              Gremlins?
              At this point, I honestly wouldn't be surprised if it was lol
              • Gina82
                • Oct 2017
                • 98
                Re: C284e
                So I swapped the staple cartridges around as suggested first. This seems to have fixed my problem. I have checked on this machine twice since then and is running like a champ so far.
                Thanks for the help!
