Noise bizhub 458
  • allan
    RTFM!!
    • 5459
    #16
    Re: Noise bizhub 458
    Take a busing from a bizhub 223 feed unit, you know the black ones.
    Then take the worn out part from the 458 and fit the bushing center to where the hole for the shaft should be by drilling and using a file.
    You can fix the bad part to use again.
    When i received the first new part i did not even bother to install it, i removed and fixed the existing one.
    The same thing was bound to happen with the replacement as there was no revision done on it yet.
    Whatever
