I want to help
  • tech jalal
    • Mar 2019
    • 4
    [Error Code] I want to help
    error 4802 bizhub c284
    I am a technician and I have a book
    • 22808
    Re: I want to help
    Originally posted by tech jalal
    Re: I want to help... error 4802 bizhub c284
    yup it's messed up! It's more like " Re: I NEED some help "
    what have you done?
    have you googled the problem?
    do you have the service manuals?
    are you a tech?
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      Re: I want to help
      what have you done?
      are you a tech?
      My general analysis on tech or not is if in their post, they don't mention a thing that was done, as well as that being their first post= not a tech.
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • 22808
        Re: I want to help
        to a certain extent I agree... I (wrongly) made that assumption about a month ago... seems that person had been in the industry the same amount of years as I and got rather 'huffy' with me about it.
        So now I try to be a more 'humble and quieter Pooh Bear"
        • allan
          RTFM!!
          • 5446
          Re: I want to help
          He left a clue. He is tech jalal.
          So what have you done so far?
          Looks like the old board switcheroo went haywire.
          Googled the solution in 5 seconds flat!
          Error Codes > Konica-Minolta > bizhub 364e > Code C4802
          Whatever
            • 22808
            Re: I want to help
            don't edit the original post.. you DIDN'T mention ANY of that in OP.
            • allan
              RTFM!!
              • 5446
              Re: I want to help
              Oops just edited my previous post above.
              Don't want to upset the whip.
              Whatever
                • 22808
                Re: I want to help
                I googled it also.. found same results....
                he never mentioned what has been done...
                if you notice he edited OP from " I want to help error XXX model XXX"
                as been said.. I don't think he IS a TECH or has the manual...
                therefore done here.
                • tsbservice
                  Field tech
                  • 7711
                  Re: I want to help
                  Q:Messed up with board replacement(PRCB) without data backup before?
                  A:Most probably-Yes
                  Q:Cannot enter service mode?
                  A:Most probably-Yes
                  Solution:
                  Hire a tech.
                    • 22808
                    Re: I want to help
                    A:Most probably-Yes
                    A:Most probably-Yes
                    Solution:
                    Hire a tech.
                    Ohhhh... but he IS a tech WITH manual (bwahaha)
                    He still hasn't answered WHAT has been done...
                    but he was kind enuff to edit the OP from mode/code to
                    "Am a tech with manual" but left out the error code!
                    O
                    • tech jalal
                      • Mar 2019
                      • 4
                      [QUOTE = Phil B.؛ 739430] Ohhhh ... لكنه تقنية مع دليل (bwahaha)
                      لم يرد بعد على ما تم القيام به ...
                      لكنه كان محققًا جيدًا لتحرير OP من الوضع / الرمز إلى
                      "أنا تقنية مع دليل" ولكن استبعد رمز الخطأ!
                      O [/ QUOTE]
                      توقف الحل 00 توقف وضع الخدمة 01 c 0 وضع تحميل بيانات المحرك نعم موافق قم بإيقاف تشغيل مفتاح الطاقة الرئيسي وقم بتشغيله مرة أخرى أكثر من
                      • tech jalal
                        • Mar 2019
                        • 4
                        Re: I want to help
                        O
                        stop 00 stop 01 service mode stop 0 c[Engine Data Backup] [Engine Data Load mode] [Yes] “OK” Turn OFF the main power switch and turn it ON again more than 10 seconds after
                          • 22808
                          Re: I want to help
                          O [/ QUOTE]
                          WTF? is this?
                            • 13349
                            Re: I want to help
                            WTF? is this?
                            It looks like a language other than english. They do exist you know. Lol
                              • 22808
                              Re: I want to help
                              well aware of other languages... but it doesn't look like french or german..
                              I thought we had an understanding to post in english @ CTN..
                              I mean it is located in the USA.. "when in Rome....."
