email notification konica 4 series and others
  • lucycopy
    • Jan 2019
    • 22
    Goodmorning everyone
    I set up e-mail notifications for the toner out of the konica series 4 and others.
    notifications arrive when the toner is completely used up and the machine is stopped.
    Is it possible to get notifications before the machine stops?
    or set a toner percentage when sending the notification?
  • lucycopy
    • Jan 2019
    • 22
    Re: email notification konica 4 series and others
    Originally posted by alamsandhu
    you can set the notification as alert with Percentage.
    better to use print fleet!
    how can i set the percentage?
    • tulintron
      • Jul 2014
      • 668
      Good Morning. Just send toner exchange message. For more control, use Prinfleet software.
      • Bix
        • Apr 2018
        • 1421
        Hi, the best system is Printfleet or CSRC.
        However, if you want to change the value, you need to modify the Dip-Switch 151
        • lucycopy
          • Jan 2019
          • 22
          what changes should I make to the dip-switch 151?
          • tsbservice
            Field tech
            • 8001
            Hi Bix, sorry but don't think it's possible for machine to send email notification before toner runs out, not in the way OP asked.
            There was such topic here, read emujo's post:
            Konica Minolta Low Toner Alert Notification
            Also in new 8 series manual, there is no mention about advanced notification only notification when toner runs out.
            Web Management Tool
            • Bix
              • Apr 2018
              • 1421
              Web Management Tool
              Hi, you're right, maybe I wasn't very clear in the message.
              I refer to the modification of the Dip-Switch only to modify when to send the warning for the level when configuring the connection via CSRC.
              For printfleet instead you can do it directly from the software.
