connection dropping bizhub c350
  • Scottyj
    • Jun 2010
    • 17
    [Misc] connection dropping bizhub c350
    Hi All,
    I have a bizhub c350 and when I print from any computer on the network (windows or mac) it fails to print.
    when I switch machine off and back on it prints and jobs that were in the queue.
  • Flash
    • 378
    Re: connection dropping bizhub c350
    That crusty old machine will not work on a gigabit network. Put a 10/100 ethernet switch between the copier and your network to slow down the network speed.
    • Scottyj
      • Jun 2010
      • 17
      Thank flash (i think), crusty old machine indeed. hard to beat print quality and just chuggs away with some TLC.
      I have a 10/100 switch in place and machine has been running on the same network set up without a problem for a few years.
      The only issue we had was a message saying 'Black imaging unit needs changing soon' (or something like that). I had the same message for weeks and was expecting it to eventually quit altogether, but it didnt. However, this is when it started to reject any prints sent to machine.
      I replace black IU. prints great but still dropping connection.
      Any ideas?
      • Gaffers01
        • May 2011
        • 335
        could be an ipconflict, try turning the machine off. and ping the address of the machine and see if you get a reply.
          • 30267
          switch are backward compatible, sounds like maybe printing is using wsd port instead of ipaddress
          • Flash
            • 378
            Does it have a Fiery print controller or the standard contoller?
            • Scottyj
              • Jun 2010
              • 17
              Thanks for your comments guys,
              look like it was an ip conflict, thanks Gaffers01
              all sorted
