Ikon CPP550 (KMBH Pro C5500) supplies and parts
  • Desert Rat
    • May 2008
    • 1089
    I think I know the answer but feel better making sure. I have a customer with one of these units and
    it is due for a tune up. The parts I'm finding are for the C6500 which I'm sure will work and others are
    for the C6501. I'm changing the drums, developers and rebuilding the transfer belt unit.
    I'm finding the same for the toners, will the 6501 toners work in the C5500? I know the bottle may
    not fit smoothly but will the toner work OK?
    DR
  • Toxic
    • 691
    Re: Ikon CPP550 (KMBH Pro C5500) supplies and parts
    Yes,toner powder is the same.
    Friend of mine use TN-612 and cut some piece of plastic on top of the bottle and use in C5500.
    For 6501 i use DU-104 drums.
    • Desert Rat
      • May 2008
      • 1089
      Toxic,
      Thank you for a quick reply.
      I have found a set of the DU104 drums. I also found a transfer kit and developers. I have a set of chargers I can clean. I also have a couple of
      organic drums. I just don't know if the drive cog is the same, I'll have to look at them again. I got them from Precision Roller.
      I need my customer to pay for the parts in advance because
      business has been really slow for to long. And I am getting ready to retire in about 1 or 2 years. I'm
      ready to move on and go fishing more often then not.
      Thanks again
      DR
