bizhub 601 user box does not show save documents option
  • Gulbadin
    • Nov 2017
    • 22
    when i go into the user box only use document and save document option are present. HDD is installed into the copier. but when i check it in service mode the HDD shows unset. please guide me how to fix this problem.
    Re: bizhub 601 user box does not show save documents option
    that should be covered in the service manual
    • rrrohan
      • Sep 2011
      • 1977
      have you tried going into system 2 - HDD - and changing it to SET ? I assume you have but you never said what you tried
      also considering these are PATA/IDE drives it might of just died due to old age
