Bizhub C558 Account track, maximum allowance
  • wesdog
    • Oct 2010
    • 10
  • ayeright
    • Feb 2011
    • 74
    Re: Bizhub C558 Account track, maximum allowance
    There's an option in the setup to stop printing when job limit is reached, not sure if that would hold or delete further jobs/printing? I think the default is delete but don't have a machine to hand to confirm this.
    Could you default the print queue to 'Secure print'? That way the user would be in front of the copier when the limit is reached and the jobs would be held in the queue? You can put a shortcut to Secure Print on the Home screen to make access quicker.
    • wesdog
      • Oct 2010
      • 10
      Forgot to say they also have the lk114 serverless pull printing licence kit so they retrieve their jobs from that shortcut.
      do you know where the option is for stop printing when job limit is reached?
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Might try looking in here:
        User's Guide
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • wesdog
          • Oct 2010
          • 10
          User's Guide
          • tsbservice
            Field tech
            • 8016
            Descriptions of Functions / Utility Keys
            • srvctec
              • Oct 2009
              • 827
              You can't log into the machine as administrator while a job is in the printer's queue anyway, so it wouldn't matter if there was a way to prevent deleting the job after maximum allowance has been met.
              • B0265
                • Jan 2007
                • 718
                Never tried combination this so I'm curious about a couple of things.
                Do you use account track as the authentication metod?
                Are the jobs visible in the LK-114 job list even after the limit is reached?
                • wesdog
                  • Oct 2010
                  • 10
                  Hi
                  User Authentication on MFP is the Auth Method with y soft card readers and cards
                  Yes the jobs were in the list still but you could not print them.
                  We have sorted the issue now with changing WHEN # OF JOBS REACH MAXIMUM Setting to Stop Job rather than Skip or delete.
                  Customer can now log in through web browser and either reset the limit or increase the user's allowance.
                  Thanks for all your help guys.
                  • wesdog
                    • Oct 2010
                    • 10
                    You can on the new range of bizhubs, but not the earlier range.
