DI620 - URGENT HELP! Need to force output to bottom offset Tray
  • mrbreak3r
    Hey,
    Great site, i really need some help - my photocopier is sending all copies to the Top offset tray - however it seems to get jammed always at the final roller!
    It works perfectly when it gets to the Bottom Offset Tray - but it just sends it to the bottom offset when it feels like it.. i need to set the photocopier to send all copies there. i have gone into the Utility>users choice priority offset tray>Bottom Tray. but it still comes out on the top offset tray.
    Can someone please help me, we are running a special promotion that was meant to go out yesterday!
    is there a special way i am meant to load the paper? to make it go there? etc..? for some reason it started sending it to the bottom but i dont know why and cant get it to do it again.
    is there anything in the tech section Utility meter count - stop00stop01? that can do it?
    is there any premium rate telephone line that someone can help me over the phone! i really am desperate!
    Please help!
    Thanks Alex
  • kmcopier
    PSP
    • Oct 2008
    • 183
    Go too the finsher menu in the service mode there you can set that it for which tray
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      try that again ...
      hi men..don't desperated my friend technician but you controled all sonsor of this di620 l thing it's responsibole normaly.....
      BEST TECHNICIAN . NICE PEOPLE .
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Here is something to look for. If it sorts it will use the lower tray, so make it sort!!!!
        • 10871087
          • Jan 2005
          • 1062
          I found this in the Di620 Operator's Manual, it should change your default output tray.
          Press the "Utility" key
          Press "users Choice" on the touch screen
          Go to page 6/6 and select "priority Offset Tray" and set it to wherever you want your paper to come out of.
          If in doubt RTFM, If that doesn't work, Call a tech and get your machine fixed.
          • mrbreak3r
            Thanks for the help guys - all great suggestions, i figured out what the problem was..!
            If you select Exclusive Paper - in the manual feed section - regardless it will always send it to top tray.. the trick is to not press that button (even if it is special paper - if you want it to definately come from the bottom..
