C-E202 C754
  • Kenny
    • Jun 2009
    • 526
    C-E202 C754
    Got a machine throwing above error up, going in today to clear all memory and reformat
    just wondered if anyone has come across this before as first time for us
    Failing all MFP will need to be swapped
    thanks as always chaps
    Kenny
  • tsbservice
    Field tech
    • 8016
    Re: C-E202 C754
    Are you sure about error. Can't find such.
    • Kenny
      • Jun 2009
      • 526
      Re: C-E202 C754
      yes see attached
      kind regards
      Kenny
      • korthr5
        • Feb 2016
        • 39
        Re: C-E202 C754
        This error normally, solved by updating the firmware.
        • tsbservice
          Field tech
          • 8016
          Re: C-E202 C754
          Agree with korthr5, update Firmware... Found that for E-series, should apply to your case.
          "When an MFP is receiving printing data but it stops receiving the data for any reason and does not print the data, the MFP can reboot automatically by making trouble code C-E202 occur."
          • kashif
            • Apr 2013
            • 45
            Re: C-E202 C754
            before firmware check HDD, may be cause HDD
