8 series intermittent jamming from all trays
  • tsbservice
    Field tech
    • 7930
    CAUSE: Paper feed roller (p/n A00J563600) is slipping on the hub.
    SOLUTION: As a temporary solution glue the feed roller to the hub.
    KBA00034433
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: 8 series intermittent jamming from all trays
    Hi,
    You should be using part number A64J564101.
    • rrrohan
      • Sep 2011
      • 1977
      i still use A00J on 8 series, no problem so far
      • Bix
        • Apr 2018
        • 1421
        what does "glue the feed roller to the hub" mean?
        I do not understand what is meant by a hub
        • tsbservice
          Field tech
          • 7930
          It's 'Nabe' in German I believe
          The black plastic center part of rollers. Imagine feed drive rotates this hub but the rubber roller is sleeping on hub.
