B227 drum units not running yeild
  • Brett GS
    • Jun 2013
    • 154
    Hi all
    Anyone else sitting with B227 drum units that dont run yeild?
    I have had a few that bearly get 20k,have replaced drum,dev unit and transfer roller at the same time but still the drum wears on the edges.
    All original KM parts.
    • 15069
    Re: B227 drum units not running yeild
    Our experience has been getting yield but no more. With the transfer roller, instead of a corona, they wear faster.
    • qbert69
      • Mar 2013
      • 1152
      I know on Kyoceras they have rubber charge rollers that get nasty with paper dust. Over time they will degrade from the oxidizing ozone & eventually get high voltage bubble/pop/arc spots in the rubber. Life on the charge rollers is generally 80k & at best 120k. Their amorphous silicon drums are supposed to last to 600k!!! Weak point is the charge rollers without a doubt!!!
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • allan
        RTFM!!
        • 5462
        Check it the metal guide on the transfer roller assy is not bent.
        Whatever
        • allan
          RTFM!!
          • 5462
          If the machine runs good volume you can get 400K on a drum.
          Whatever
            • 15069
            That is quite true for the C360 and 4 series. The 8 and 7 series machines, high or low volume, get to yield or a bit over and then lines develop.
            KonMin wasn't selling enough drums so they went to the charge roller design so they would fail sooner and thus sell more drums.
            • allan
              RTFM!!
              • 5462
              True for the color machines yes but this b/w box rocks and makes real good yield on volumes.
              Whatever
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                I think there is some truth to this as well. I know we've had some low volume 4e machines come back out of the field after three years or so and never had to change a drum. They should offer replaceable charger units.
