LCT Ribbon Cable Torn c-0215
  • HostileHare
    • Sep 2015
    • 7
    [Error Code] LCT Ribbon Cable Torn c-0215
    Hey folks, I have a customer with a Konica Minolta Bizhub C360 with a torn ribbon cable in the LCT. I'm struggling to find the dumb cable. Its the orange one the connects to the back of the LCT. Its visibly ripped, casausing a C-0212 code. I need a part number for it, TIA!!
    • 14754
    Re: LCT Ribbon Cable Torn c-0215
    It is called a PWB assy. Part number is 4479010503
    • HostileHare
      • Sep 2015
      • 7
      This is coming up as the PWB in the standard cassettes, the ribbon cable that is torn is in the LCT, is it still the same part?
      • B0265
        • Jan 2007
        • 718
        That part number should be correct.
        • HostileHare
          • Sep 2015
          • 7
          Thank you very much!! I appreciate the help!
          • HostileHare
            • Sep 2015
            • 7
            Ok, i have 7 days before the part comes in, is it possible to disconnect the LCT so the machine will run in the mean while?
              • 14754
              On the back of the machine there is a small cover in the middle at the bottom. Under this cover there are some connectors. Disconnect these connectors and the machine will work. Be sure to turn the power off and unplug the machine before doing this.
