How to disable the wieving of the job log in PSWC?
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Hi you all.
    I was asked from the IT specialist of one of my customers , to find a way to disable the possibility to wiew the job log who contains the domain names of the users.
    Disabling PSWC turning it off isn't an option. The Customer has about 100 MFP's in multiple offices and cities.
    Tried a password for the public login, but in that state the MFP became not fully usable.
    Thanks for your ideas
    Aldo
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
  • rrrohan
    • Sep 2011
    • 1977
    Re: How to disable the wieving of the job log in PSWC?
    i think the feature your after is
    Hide Personal Information (MIB)
    • tsbservice
      Field tech
      • 7968
      Try to modify switch 75 to HEX 08.
      That should mask job history for users other than administrator in PSWC.
      • rrrohan
        • Sep 2011
        • 1977
        thats handy to know. pity KM dont list this in the manual for some reason
        see image below. Job at top of job is after software switch set, all jobs below it are prior to changeprivate job history.JPG
          • 14489
          I can't remember who's copytechnet signature this is but it's so true.
          "90% of IT is a solution looking for a problem"
          Makes me chuckle every time I see it.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            What models does this apply to? We just tried it on a C360 and the job log is still viewable through PSWC, public account.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • allan
              RTFM!!
              • 5462
              Do you have the latest firmware on that 360.
              Who has a list of all the engine and system switches on these machines?
              Whatever
              • srvctec
                • Oct 2009
                • 827
                Yep, D2 is installed and the latest I'm aware of unless it takes a special F/W to make this work.
                I should clarify that the C360 let us change the SW75 to 08, but after going back in to view the SW, it was back at 00. Apparently it won't allow that one to be changed.
                Yeah, I'd love to have a list of soft switches for each machine like Minolta used to provide us 20-25 years ago. It was in every service manual and if we weren't supposed to change it, it said not used in the field. My guess is that too many techs started changing soft switches they weren't supposed to at some point and the powers that be decided not to provide the list any more.
                • srvctec
                  • Oct 2009
                  • 827
                  We also just tried the SW75 to 08 (it actually held the setting) on a C284e with the latest F/W (GHV-M1) and all jobs are still viewable via PSWC public account as well.
                  • allan
                    RTFM!!
                    • 5462
                    When you change some menu items you actually change the switches in the background.
                    So it could be that there is an admin setting in plain sight that is being missed.
                    Function version? Would that matter?
                    Whatever
                    • srvctec
                      • Oct 2009
                      • 827
                      On C284e, function version is 7. C360, the function version is 3 but on those, there isn't a way to change it as the F/W update automatically changed the function version.
                      • allan
                        RTFM!!
                        • 5462
                        Found it in the manual...
                        Under Enhanced security mode under security in the admin settings.
                        Did you restart the machine?
                        Whatever
                        • srvctec
                          • Oct 2009
                          • 827
                          Yep, shut both machines down after changing soft switch 75 to HEX 08. It seems it just doesn't work unless the SW or HEX assignment aren't correct, maybe?
