C5501 report Exchange time of toner filter
  • lt.Botary
    • Aug 2025
    Using Konica Minolta bizhub C5501 & Fiery ... controller.
    At this moment printed 105k copies and appera on screen
    exchange time of toner filter
    We not found In Service Manual what to do to fix wranings.
    Any body know?
  • kmcopier
    PSP
    • Oct 2008
    • 183
    replace them and then reset the counter in the pmcounters for parts
    • lt.Botary
      I can`t find counter for toner filter...
      Counter for Toner collection box reseted, but nothing happens.
      • random
        This is not the toner collection box. This is the Toner filter which is located on the right hand side of the machine towards the back behind a panel. You will have to either have CMS enabled or have access to service mode to reset this counter. Depending on how you machine is set up it will stop if you don't reset the filter. You should not leave the old filter in as this will increase wear on the machine.
        • lt.Botary
          Resourse for changing 600000 copies, but we made only 105k.
