Scan to SMB Login Error
  • beowulf
    • Mar 2019
    • 22
    Hello Experts!
    I was wondering if you guys can give me a piece of advice or any useful tip to solve my issue with Konica Minolta bizhub 367 scan-to-SMB.
    Error Details: Login Error
    Network Error Code: N/A (Didnt turn that option ON)
    Operating System : Windows 10
    User ID is outlook/hotmail microsoft accounts ID, Password is PIN. On the other hand one user is using separate user name and password but error is same. Login error. I have entered user name and password correctly. double checked that. I have also enabled SMB Authentication in network settings to NTLM V1 & V2 but error is same.
    IF THIS IS DUE TO ANY WINDOWS UPDATE WHICH DISABLE SMB PLEASE GIVE ME SUGGESTION!
    Many Thanks in advance
    Re: Scan to SMB Login Error
    Originally posted by beowulf
    Hello Experts!
    up grade firmware?
    u
    • tulintron
      • Jul 2014
      • 666
      Hello Experts!
      Windows 10 came with enhanced security system, locking protocol versions SMB v1 and v2.
      I do not remember which versions of SMB the Bizhub 367 has available. If it is not compatible, try talking NTLM 1.0 and 2.0.
      If it does not resolve, you can also unlock SMB 1.0 and 2.0 protocols in Windows 10.
      However, the system will be vulnerable, less secure. Many do not recommend this method. But you will have no choice.
      https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
      • darry1322
        • Oct 2010
        • 817
        Scan to ftp is a choice. Install basic ftp server through the OS or an ftp server utility ( Filezilla, Quick-n-easy ftp).
          8T6 4T7
          • 15302
          Turn password protected sharing off in the network and sharing center, advanced sharing setting
          • mincopier
            • Dec 2015
            • 289
            Highlight the folder you are scanning too:
            Properties
            Sharing tab
            Advanced sharing
            Make sure the account you are using is listed, give full rights
            Konicaminolta has it's own FTP utility that works well.
            You can also look at the event viewer to see what is going on:
            Run
            Event Viewer
            Applications and Services Log
            Microsoft
            Windows
            Scroll to SMBClient, SMBDirect, SMBServer
            Depending on where the error occurs one of these will have an error under Connectivity, Operational, or Security. Just look at the times. If no errors are found for the time that the scan is done the machine is never getting a communication to the computer. This then becomes a network issue. FTP may still work, just means there is a SMB protocol related issue of some kind. I have seen various errors such as Authentication error, SMB V1 communication attempt, and SMBV2/V3 attempt.
            In some case you can try changing the user from Standard to Administrator or the other way around.
            If wireless, I have had better luck with wireless set to Private instead of Public.
            • beowulf
              • Mar 2019
              • 22
              Thank you very much for your generous reply.
              I have checked NTLM V1 and NTLM V2 both but error remains same. How can i unlock SMB 1.0 and 2.0 Protocols in windows 10?
              • beowulf
                • Mar 2019
                • 22
                Thanks for your reply.
                I never tried setting up FTP server option. Can you please guide how to do that?
                • rrrohan
                  • Sep 2011
                  • 1973
                  Password is PIN
                  pretty sure you cant use the PIN method to authenticate youd need to use the full password
                  norm what i do is plug my own laptop into customers network and try to browse to exact folder share as copier is trying to scan to.
                  use the same login credentials as your using at the copier and see if it also fails.
                  if it does then its a credentials issue or similar. if it works then you know copier just needs tweaking
                  have a read through this if you dont want to install a dedicated FTP server program
                  How to set up and manage an FTP server on Windows 10 | Windows Central
                  if your just making the root directory of ftp the scan folder in folder path just put " \ " backslash
                  Last edited by rrrohan; 05-13-2019, 03:09 AM. Reason: added FTP server setup guide
                  • acidus
                    • Feb 2015
                    • 4
                    Control Panel - Programs and features - turn windows features on or off - In the next windows are two SMB options to select. I install both everytime i need to handle sharing to windows 10. Remember to turn off password sharing to make things easier.
                    Hope it helps.
                    • Bix
                      • Apr 2018
                      • 1420
                      Hi, if login error occurs check username or password.
                      If it has both pin and password, you use the password.
                      To be sure of the username, open the CMD on Windows and type "set user".
                      The username is "USERNAME".
                      • NeoMatrix
                        Senior Tech.
                        • 3510
                        Scan to FTP using an in house LAN NAS...
                        The same NAS can be configured port forwarding for the WAN.
                        htttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software-10.html#post694379
                        http://www.copytechnet.com/forums/co...tml#post694379
