KM and Papercut
  • cgorms
    • May 2019
    • 2
    KM and Papercut
    The initial installation was 17.0 PaperCut, the customer performed an 18.3 upgrade unknowing the advanced settings for the devices where not altered accordingly, this caused SHA1 issues.
    The customer installed a new VM Print Server with new queues for the 14 KM devices, this was followed by a new PaperCut 19.02 installation no previous data was migrated. The embedded manual for the devices was followed.
    Previously devices where running the following firmware with functional level 4.2, this however caused FA14 errors on the devices
    • C308 - GC1-W4
    • C458 - GC1-W5
    • C308 (ZeusS 1/2 series) Periodic Firmware release 2, Function version 4.1, OpenAPI 5.1 / IWS 2.5.5 GC3-S1
    • C458 (ZeusS Z/X/0 series) Periodic Firmware release 2, Function Version 4.1, OpenAPI 5.1 / IWS 2.5.5 GC3-R9
    The FA14 errors appear to have stopped but as mentioned the devices when waking from sleep are not functioning as excepted - touch panel, Access and Menu buttons are unresponsive and the card reader does not scan.
    Low Power Mode Settings - 15 min.
    Sleep Mode Settings - 30 min.
    Power Key Setting - Sub Power OFF
    Power Save Settings - Sleep
    Enter Power Save Mode - Immediately
    Power Consumption in Sleep Mode - High
    Power Saving Fax/Scan - Standard
    Awake from Power Save Mode by Touching Control Panel - ON
    I'm assuming this issue is unrelated to Papercut but maybe wrong. Can anyone assist?
  • mo0651
    • 1054
    Re: KM and Papercut
    Did you see the post just 5 ahead of yours??????
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: KM and Papercut
      Re. Five CTN posts ??????
      All I see here in OZ is two forum posts in total.
      htttp://www.copytechnet.com/forums/konica-minolta/138936-km-papercut.html#post755835
      http://www.copytechnet.com/forums/ko...tml#post755835
      htttp://www.copytechnet.com/forums/konica-minolta/138936-km-papercut.html#post755780
      http://www.copytechnet.com/forums/ko...tml#post755780
      • tsbservice
        Field tech
        • 8020
        Re: KM and Papercut
        Neo, put on your glasses.
        KM458 and 558 running Papercut C9401 and FA14
