Bizhub 42 with Scanner Locked error (belt broken)
  • ricmartinho
    • 142
    Hello!
    We have a machine that has the scanner belt broken. I looked in the Parts Catalog but there's no part number for the belt, only for the entire scanner.
    Does anyone know the part number for the belt?
  • ricmartinho
    • 142
    Re: Bizhub 42 with Scanner Locked error (belt broken)
    I've found it! The part number is A121PP0N00.
    Should've searched before posting. Hope it helps someone.
    • Downunder
      • Aug 2007
      • 174
      try this number
      A121PP0N02
      • 907tec
        • 438
        Still can't believe that they continue to use the C35 scanner belt, despite the insane failure rate. I've ordered so many of those belts that the mere sight of the part number raises my blood pressure.
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          Yeah, they are complete junk because of the crimp going the wrong way. All they needed to do to fix the issue was to put 3 or 4 crimps, PERPENDICULAR to the belt instead of in parallel with it and it would probably last for a very long time. With the crimp in the brass part right in the center and parallel to the fibers of the belt, it's no wonder the thing slips apart.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • moses smith
            Senior tec- self employed
            • Mar 2013
            • 4
            Hi
            u can use the scanner belt of any inkjet or hp inkjet that has the same profile. i use a small cable tie to fix the ends.
            • Sysco
              • Mar 2010
              • 43
              Here is the part number:
              A121PP0N02 Scanner Belt
