FS 534 SD BIZHUB C224
  • jaime cruz barron
    • Jun 2019
    • 2
    Hello i need to know if i can place a finisher fs-534sd of a bizhub c224e equipment in a bizhub c368 / 308 equipment
    thank any comment.
    Re: FS 534 SD BIZHUB C224
    thank any comment.
    that should be covered in the Sm.
    • tsbservice
      Field tech
      • 8016
      Yes.
      thank any comment.
      And yes, you are lucky today
      • emujo2
        • Mar 2017
        • 1579
        thank any comment.
        I'm not so sure..the combo FS534 and SD-511 are shown as the same for the 224e and the C368, but the C368 cannot use the relay unit that comes with the older 224e..The C368 now needs the RU-513..Not sure if the older finisher boards support this.
        • tech51
          • 846
          I think you may run into firmware issues as well.
            • 14726
            I have used the FS534 from a 4 series with the relay unit on an 8 series several times without any problems. I have updated firmware and the machine takes it just fine.
            • jaime cruz barron
              • Jun 2019
              • 2
              Thank you very much for the contribution.
              You could tell me what firmware version you used.
                • 14726
                Well, if you are installing the finisher on a C368 series machine you would install C368 series firmware.
                • tech51
                  • 846
