Product name is CSRC?
  • rrrohan
    • Sep 2011
    • 1977
    What it mean by version?
    I just looked at 2 different B958's in CSRC and one was called B958_Ver41 and the other is B958_Ver32
    Is this just referring to how many modifications its had since the first copier came of the production line?
  • tsbservice
    Field tech
    • 7942
    Re: Product name is CSRC?
    I think it may be FW Function version. One with ver41 should be at R9 FW level, and another maybe G9.
    • rrrohan
      • Sep 2011
      • 1977
      ill double check but i dont believe so
      its just we had some issues with the B958 ADF not latching down well causing problems with gears meshing and it seems to be more of a problem on the 958's we sold early on in the release
      • Jumping Jack Flash
        • Jul 2009
        • 64
        HI, Have you already solved this problem ?
        • Bix
          • Apr 2018
          • 1421
          That value simply indicates the software version of the printer. Read it in Utilities> Device Information.
          The last firmware is 4.2
          In addition, some recently installed printers may have changes compared to the printers installed a year ago, in addition to the new FW already installed.
            • Jul 2009
            • 64
            HI Bix, I have a question for you.
            If you use CSRC you will ecounter that a machine shown another model name than it is.
            I would like to know does CSRC`s communication always is correct from CSRC?
