Anybody have the touchscreen stop responding on a Bizhub C550? Recalibration doesn't work, reseated the touch panel connector along with all the other connectors on the panel, utility key reset done and still nothing.
Bizhub C550
Are u able to do copies
Hi,
Are u able to do copies.it might be a NVRAM prob.
Try to make a copy or give a print from the PC.
Let us see wat happence.
with regards
SudhakarComment
Re: Bizhub C550
If it s working with a PC or Fax then it is definitely Screen. Most likely need to Change Touch Screen.Comment
