Bizhub C308 weird color registration/ print head problem
  • SAR
    • Jul 2009
    • 182
    Any color copies /prints come out with black lines all over them with color registration way off. Black and white copies and prints are fine.
    Copier had some P-21 and P-28 warning codes. Transfer belt has been replaced and IDC sensors cleaned. Tried to run Gradation, but Stabilizer comes up NG.
    Have tried Initialize/ Image Stabilization, Print head skew reset. All consumables are in good shape.
    I'm thinking it's a bad print head, but wanted to see if anyone here has seen this.IMG_1979.jpgIMG_1980 (2).jpg
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub C308 weird color registration/ print head problem
    I'd re-secure all plugs on the MFPB and PRCB as well as re-seat memory and NVRAM. Also maybe re-secure plugs to AIDC board assy as well. If you have another machine to take parts off of, take the AIDC board assy and swap it to see if there is a change. If no change then I'd say PH unit from the looks of it.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • docdot69
      • May 2016
      • 53
      If You wanted to save money, and put drum k with color chip, thats the result, because KM is smart, and they changed a little drums K, to avoid putting them into colors place. Just try to swap with old color drums, or if you have other machine, swap drums between them. Just to try.
      • tsbservice
        Field tech
        • 7635
        The only common parts between P-21 and P-28 malfunction codes are transfer belt unit and IDC sensor shutter solenoid SD2.
        Since TBU is new I will concentrate on SD2. I will also check both IDCS sensors values in service mode for abnormal values.
        Can you see how color patches are formed on belt?
        • tech51
          • 846
          • SAR
            • Jul 2009
            • 182
            Thank you for the replies! I replaced the print head in the copier and it fixed the problem.
            • bitels85
              • Jun 2015
              • 8
              Hi, I recently have excatly the same problem in Develop ineo +308 copier
              I took out laser unit and cleaned it. I was extremely careful, so I'm pretty sure I didn't damage it in anyway.
              After that, printing quality became perfect, but only for one day
              Before replacing laser unit I will try reconnect all plugs on MFPB, apply latest FW, and perform initial troubleshooting procedure and engine troubleshooting procedure.
              Somehow, I'm not convinced that laser is broken...
              • WLIT
                • Jan 2020
                • 40
                I have fixed numerous C308 machines by removing the guide plate above registration where the IDC sensors are located and cut the tie wraps to the sensors and the rest of the harness. The wire harness goes to the front PCB behind the waste toner container so the front inner covers need to be removed. If you want to you can check the reading of the IDC sensors in Service mode> State confirmation> Level history 1. If your machine is in a warning with the oil can showing in the top left corner when you enter Service mode, the values of the IDC sensors will be off or may not even show. Think they should each be around 3 volts when normal.
                • bitels85
                  • Jun 2015
                  • 8
                  I just remembered that this particular copier had this problem before in 2019. I found demo page in my documents (attachment). Problem was solved without replacement any of parts. Hope this time will be the same way. I'll let you know soon.
                  • jotunn
                    • 530
                    Take apart PH Unit and gently clean up polygon mirror, and SOS sensor. PH Unit is not hermetically sealed, so polygon grabs a lot of dust, and C308 is surprisingly sensitive to this problem.
                    • Gift
                      • Mar 2011
                      • 2412
                      I find this series pretty stable - we refurb them regulary and I always perform full page test patterns with different densities for each color to check if theres a need to clean the laser - usually it's looking fine.
                      • bitels85
                        • Jun 2015
                        • 8
                        You were absolutely right.As I told before, I've cleaned PH unit already but today, when I inspected it again, It came out, that I've missed one side of polygon mirror(added picture).
                        After cleaning it, everything works fine. We did many tests and printed about 1K color pages. There is no need to replace ph unit and that is very good news
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2142
                          Anyone else has this problem with minced up colour image which can also spread across multiple pages - I've seen it plenty.
                          It can also accompany the 9202 blank pages jam.
                          Removing and inserting the PH will be a coincidence, because the real cause is touched in this process.
                          It's most often the reseating of the connections on the front relay board that fixes it, or replacement of this board. This board can also be corrupted by the (frequent) spillage of the waste toner by imbeciles.
