C6500 color registration assy sensor C-4521 error
  • joaodaffonsojr
    • Aug 2014
    • 53
    Hi !
    I need to replace this sensor !
    But i don't want to buy the role color registration assy.
    It's possible to know the part number only for the sensor?
    Thanks !
  • tulintron
    • Jul 2014
    • 668
    Re: C6500 color registration assy sensor C-4521 error
    Originally posted by joaodaffonsojr
    Hi !
    Thanks !
    [ATTACH=CONFIG]43036[/ATTACH][ATTACH=CONFIG]43037[/ATTACH][ATTACH=CONFIG]43038[/ATTACH]
    This set has only one code.
    No parts found
    • tulintron
      • Jul 2014
      • 668
      • lucky13
        • May 2008
        • 125
        i dont see a part number for that sensor looks like all in 1 unit what you can do is take the tiny clear cover off the front of the sensor and blow the dust out and switch it with the other one they are the same see if you get a different code , also how many prints on the trans belt and internal rollers ? developer and drum counts as well .
        these dip switches will temporally get the machine running till you get sensors sorted out
        25-5=1 color reg less percise for speed
        will disable color reg adjust till you get sensors, reg may suffer
        25-3=1
        25-4=0
