KM 4052
  • agudmove
    • Jun 2009
    • 70
    KM 4052
  • Bix
    • Apr 2018
    • 1421
    Re: KM 4052
    Hi, your looks more like a driver problem.
    Which file do you print? Did it happen by copying as a scanner?
    Here's what I recommend you set in the PCL drivers:
    With these parameters the printer seems to start printing faster (therefore less time for the first print):
    Preferences> Quality> Font type settings: Download fonts to the printer: image. I have also removed "use printer fonts"
    Then in Printing Preferences> Finishing> Paper Layout: Productivity Priority.
    • cgw71
      • 15
      Re: KM 4052
      But he did say copying right? Is this only happening with print jobs or also with copy jobs? Like 1 double-sided sheet original and copying it 50 times.
      • agudmove
        • Jun 2009
        • 70
        Re: KM 4052
        Hello guys thanks for the response, this is when copying.
        • tsbservice
          Field tech
          • 8010
          Re: KM 4052
          And you changed all that stuff just because they want to print double sided with this exact machine
          What's the jam code, does it jams on every one double sided page and where?
          • cgw71
            • 15
            Re: KM 4052
            I think this machine is actually just a rebranded Lexmark. Some of those guys might have a better idea.
            • agudmove
              • Jun 2009
              • 70
              Re: KM 4052
              The problem is that the reverse solenoid doesn't click in at any point to reverse the feed gears.
