Press C1060L
  • Shinigami
    • Mar 2017
    • 44
    Press C1060L
    Hello ,
    peoples, can you help me please in this case :
    i have the error code c3508 after each print , i rest the code with softwaredipsw 3
    but the problem is apeard again, i change the prcb , i check all the fan motor and ps22 sd 3
    but the same problem !
  • Leyahné
    • Feb 2016
    • 44
    Re: Press C1060L
    Hi have you checked the fuser belt and Lower toller, on the belt there is a thermistor that is in contact with the belt.
    Second problem in the fusing unit there is one way bearing that aids with the turning of the belt and roller and the bearing is slipping and not rotating the belt or roller with correct timing causing your error code
    Sent from my SM-N960F using Tapatalk
