bizhub c3351 intermittent error c-2155
  • POPEYE
    • Jul 2019
    • 10
    Got a service call, c3351 when switch from b/w to color print ,after color print out sometimes show c-2155. service manual said :transfer belt contact fault after k pressure established,,already replaced transfer belt ,1st transfer pressure solenoid SD-1,1st transfer pressure sensor ps9,but cannot fix the problem.any suggestion ?thanks alot
  • Bix
    • Apr 2018
    • 1421
    Re: bizhub c3351 intermittent error c-2155
    Hi, have you tried/changed the M1 motor?
    • POPEYE
      • Jul 2019
      • 10
      thanks for reply ,already ordered M1 and will be replaced soon,but I test M1 in service mode -load check mode ,it will turn ,so i think M1 seems normal
      • CraigW
        • Dec 2010
        • 417
        My boss did battle with a C3351, having 2155 under warr.
        He did M1 with no luck.
        The last thing on the list was..... "main drive assy"
        • POPEYE
          • Jul 2019
          • 10
          thanks for reply!so replaced main drive can fix it?
          • CraigW
            • Dec 2010
            • 417
            That was last item replaced.... no calls / or 2155 codes since then.
            • POPEYE
              • Jul 2019
              • 10
              Thanks alot,I will bring along main motor and main drive assy ,hope its not MFB.
              • CraigW
                • Dec 2010
                • 417
                ^^^^ He did that as well.... right before he did main drive assy
                • tech51
                  • 846
                  Definitely the drive unit. We have had two examples of this in the last couple of months. Drive unit fixed it both times.
                  • Georger@kmdirect.co.za
                    • Jan 2020
                    • 1
                    Hi Popeye,
                    Please advise if you managed to solve this errer with the main drive and advise if is possible to strip and change main drives at client site. Tha ks
                    • POPEYE
                      • Jul 2019
                      • 10
                      Originally posted by Georger@kmdirect.co.za
                      Hi Popeye,
                      YES,the main drive solved the problem
                      and I changed it at client office,the table had enough space for me to service.
