Bizhub C3351 print outlines
  • Bix
    • Apr 2018
    • 1421
    hi, to a client I inverted a bizhub 458 with a C3351 because they changed office. We also changed his drivers. But I have an anomaly: on the bizhub 458, when they print in black and white, images with a transparent background have no problems. When they print on Bizhub C3351 in black and white, the image has a kind of outline.
    In the driver I tried to set maximum photo quality, but unfortunately without success. In the driver I don't know what to try to see. One attempt I could make was to change the door to the 458 driver to see what was going on but I forgot to do.
    Someone for some advice / experience?
    • 14812
    Re: Bizhub C3351 print outlines
    If you installed the PS driver, try the PCL or vice versa
    • allan
      RTFM!!
      • 5462
      Post a sample for us.
      Whatever
      • qbert69
        • Mar 2013
        • 1152
        If it's got an outline, it sound's like the Alpha Channel of the "transparent" background is being knocked out and not flattened! Save/export whatever document/webpage it is as a PDF or use Bullzip PDF Writer....let me know what happens.
        PS--almost sounds like a "halo" or "drop shadow" effect!!!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • Bix
          • Apr 2018
          • 1421
          That's right, that's what happens.
          Unfortunately the problem comes from a management software,
          When they print in other ways, it doesn't come out.
          With Outlook it exits again.
          • qbert69
            • Mar 2013
            • 1152
            Management Software???[emoji848] Do Tell!!!
            Sent from my SM-N950U1 using Tapatalk
            • qbert69
              • Mar 2013
              • 1152
              Sounds like the picture/ graphic may be a .png, in which case, they can convert it to a .jpg with a solid white background unless of course the graphic has a text flow around the object! Have you tried exporting/ saving in a flattened PDF format before printing?[emoji848]
              • Bix
                • Apr 2018
                • 1421
                Thanks for the support,
                These are ideas that I will consider.
                I still don't understand why on 458 this doesn't happen. In the case, I'll let you know in case of updates.
