Bizhub C7000 wrinkling paper.
  • tulintron
    • Jul 2014
    • 668
    Good morning everyone. I have a Bizhub C7000 crumpling A3 paper.
    I believe it is in the fusion, but I already exchanged several pieces and without success.
    I will send some pictures and explain myself. They are towards the exit of the paper.
    A3 Face Up, Paper Curl Face Up.
    A3 Face Down, paper curl face down.
    Until the second transfer, the paper is perfect.
    The ripples alternate in frequency, size and distance between them.
    Parts exchanged.
    ADU - FUSING UNIT - PAPER EXIT UNIT - DCPS1 - DCPS2 - ACDB - PRCB.
    Firmware Upgrade to Version 40.
    Any tips are welcome. Thank you
  • Mark L
    • 7
    Re: Bizhub C7000 wrinkling paper.
    Looks like fuser separation plate worn,try a new one.
    • tulintron
      • Jul 2014
      • 668
      The fusion has been replaced by another of the adjacent equipment, in perfect operating condition.
      • Toxic
        • 698
        Do you have some FS attached to that machine or just OT?
        • tulintron
          • Jul 2014
          • 668
          Bizhub Press C7000 - MB504 - OT502
          • tulintron
            • Jul 2014
            • 668
            I found that with certain firmware, the equipment works normal, but the engine (M55-Decurler motor) stays on after the end of printing. If you open and close the front cover, M55 stops. But after work is over, it gets back on. I am currently using the V30 firmware.
            When I install the setting data list from another C7000, it crumples the sheet again.
            Maybe it will help unravel the mystery.
            • methogod
              • Dec 2008
              • 927
              check your fuser is locked in....
              also check bottom of transfer belt is level, as well as bearing is lower transfer roller...
              had this in c6501....
              • mircea
                • Feb 2014
                • 70
                hello
                you can try and remove left cover of printer and take down exit rollers.
                there are some one way gears that you can try cleaning and maybe you will get lucky.
                also you can try to check left door on adu after fuser exit there is a sponge like roller on the door. maybe that one is out of place or bearings need to be replaced.
                best of luck
                • tulintron
                  • Jul 2014
                  • 668
                  Originally posted by mircea
                  hello
                  best of luck
                  transfer belt unit has been replaced
                  left side paper exit unit has also been changed
