bizhub i-series hide the pre-installed MarketPlace Application
  • tsbservice
    Field tech
    • 7991
    Found it somewhere on cscsupport. I know this may be answered in multiple different threads but for a better searchability will post new one.
    Question: How to hide the pre-installed MarketPlace Application on the Operation Panel?
    Answer: The MarketPlace Application can be hidden by preforming the following steps.
    1. Select Utiliy
    2. Select Administrator Mode
    3. Select Network
    4. Select IWS Settings
    5. Select MarketPlace Settings
    6. Select Enable settings (OFF)
    Note: The MarketPlace buttons will be hidden in the Basic Style Menu and The Classic Style Menu.
  • mincopier
    • Dec 2015
    • 289
    Re: bizhub i-series hide the pre-installed MarketPlace Application
    i Series settings.pdf
    Been there. Had to help Konica Minolta this past with a few things when they came down to show our sales staff a few things.
    • rrrohan
      • Sep 2011
      • 1976
      does the i series have a option to disable that annoying 'screen saver'.
      I never figured out how to remove it on the 8 series so just uninstalled the screen saver API. That API Manager software is so buggy too so its a pain to have to use it
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Originally posted by mincopier
        [ATTACH]43274[/ATTACH]
        WOW, thanks for the info, mincopier! This will be a great help to access the different hard to find settings.
        Just a question though. In several places in the pdf it's mentioned to go to utility twice in a row. Are there really 2 utility choices? We don't have a machine I can check on to verify before I recreate an edited pdf.
        Under "How to program the default paper tray for RX fax (Receiving)", "Program Default Paper tray for fax reports", and "Quick Copy or Basic Setting (Classic Style screen)" utility is mentioned twice in a row.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
