5000i/5020i
  • Bix
    • Apr 2018
    • 1421
    5000i/5020i
    Hi, I recently saw the new 5000i/5020i
    What do you think? It looks like they have wireless and shouldn't cost much.
    Moreover, apparently the maintenance seems easier.
  • tsbservice
    Field tech
    • 7974
    Re: 5000i/5020i
    Search for them on MPlus, there is product tech training on those I did. You will learn something.
    1 hint - they are Brother to the bone.
    • jwai
      • May 2018
      • 506
      Re: 5000i/5020i
      yes, it's born from Brother, I guess it will be better than the Lexmark-oriented models.
      • Bix
        • Apr 2018
        • 1421
        Re: 5000i/5020i
        They have a really low cost, the quality I haven't tried with hand yet
        • jwai
          • May 2018
          • 506
          Re: 5000i/5020i
          BTW, what are the sister models on Brother?
          • tsbservice
            Field tech
            • 7974
            Re: 5000i/5020i
            Brother MFC-L6900DW and such.
            • jwai
              • May 2018
              • 506
              Re: 5000i/5020i
              I have a new 5020i printed 8K pages, now some grey lines appeared on print out,
              checked the official life of imaging unit it can afford 50K, so consider the drum can work longer.
              • REGSIS
                • May 2016
                • 434
                Re: 5000i/5020i
                Check drum unit. There is a charge cleaneron top. Should similar to bizhub 20. On those I used to remove charge wires (with cleaner) from top of drum unit vacuum it and lines were gone.
                Drum unit lasted 2-3 times more than declared. 8k is little bit early for problems but you never know what can go inside.
                • tsbservice
                  Field tech
                  • 7974
                  Re: 5000i/5020i
                  8k is nothing still probably on starter toner. Have them to move few times green tab of wire charger cleaner. Make sure there's no stuck debris in drum unit especially between charge wire and drum surface.
                  • occus
                    • 331
                    Re: 5000i/5020i
                    On the original Brother i have problems with the fusers... sometime i have to change the fuser (to low temperature)and sometime the fuser cover (paper stuck in the fuser)
                    The other parts are ok.
                    • Gift
                      • Mar 2011
                      • 2458
                      Re: 5000i/5020i
                      Image background an lines may appear if the toner empty before toner end detection. if the printer is still running with it's setup toner that might be the problem.
                      • jwai
                        • May 2018
                        • 506
                        Re: 5000i/5020i
                        They consumed the starter toner and replace with large capacity genuine toner, after 1 week they reported this issue.
                        I visited and some vertical grey lines appeared on center region of printout.
                        • jwai
                          • May 2018
                          • 506
                          Re: 5000i/5020i
                          in addition, toner cartridge reset chip for brother can be used on this KM model ?
                          • tsbservice
                            Field tech
                            • 7974
                            Re: 5000i/5020i
                            Brother has no reset chip.
                            • jwai
                              • May 2018
                              • 506
                              Re: 5000i/5020i
                              If so, on brother/KM sister models, how to identify it's a new toner cartridge?
