Hello,
I am new in the forum, and a new to printing whith pcl / ps.
We have changed our system for printing invoices to "planetpress connect", which produces PCL-output files for our Konica Minolta Bizhub C754e production printers.
As we looked at the click count, we saw, that images and barcodes are counted as color. These images and barcodes should be in graystyle, according to the settings in the software.
Of the invoice we only need two pages in color, which are printed from two different trays, all other trays could be printed in black-white.
A little background about the software:
The software take a spool file from a AS/400 IBM System, and matches all data in the spool.
These data is then merged with a html template created with the designer of PlanetPress Connect.
After that the programm creates pcl / ps / pdf - files, as desired.
All this runs in an automated process.
So we have only little options for setups in the pcl creating process.
The manufactorer is searching a solution for this problem.
Now my question is, if it is possible to set specific tray of the C754e to black-white print?
This could be a solution for between for us.
Thanks for answers.
nbf
