DF601 indicates jam
+ More Options
Posts
  • Taminol
    • 171
    DF601 indicates jam
    Hi guys,
    I have a C250 with a DF601 on it. Everytime the machine is switched on or it comes on from sleep mode the DF indicates there is a jam. I simply open/shut any of the DF doors and the fault goes away. Feeding thru the DF works fine, no reg errors or anything.
    I have tried to do the auto adjustment and reinitialize of the sensors, but they all show NG.
    Am I looking at a main DF board fault, or is there firmware I can flash to it?
    Taminol
  • Flash
    • 378
    The turnover sensor is dirty or has failed. It is PC5-DF.
    • Taminol
      • 171
      Thanks for the info Fash, I'll have a proper look at that sensor tomorrow.
      Cheers
      Taminol
      • Taminol
        • 171
        Woohoo, it worked. I changed PC5 and hey presto !!
        Thanks Flash
        • redime
          Thanks Flash
          Theres the little mirror reflector patch right there - that usually gets dirty. Instruct the keyop to wipe it with a clean finger. Keeps you from coming out next time.
          • poneyboy
            • Sep 2015
            • 25
            Re: DF601 indicates jam
            Hi,
            Thank you very much, just finished ! The sensor was good but the little mirror was dirty. Immediately after reassembling i've tried to reproduce the error, so after the KM logo i had the error before and not anymore after cleaning the mirror. It is now the same for sleep mode.
