Konica 458 533 finisher Staple alignment issue
  • DOE
    • Mar 2010
    • 258
    Konica 458 with a 533 finisher. If I make 4 copies to be stapled the second and third copy do not quite get pulled in enough and sometimes miss the staple. The second and third copy will usually stick out a quarter of an inch further than the first and fourth. Could this be the belts and if so how hard is it to replace them. I know on some finishers it's a long job.i cleaned the exit tires with rubber rejuvinator, no difference. Can it be something other than belts. Thanks
  • qbert69
    • Mar 2013
    • 1152
    Re: Konica 458 533 finisher Staple alignment issue
    Does the paper come out curled or cupped??? If so, then paper has moisture in it!!! I had this happen...tried different, better, dry paper stock which layed & stacked flat & stapled just fine. [emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • DOE
      • Mar 2010
      • 258
      Going to try this but paper comes out flat no curl.
      • guitar9199
        • Sep 2016
        • 1100
        Sometimes simply cleaning the reverse rollers and belts just isn't enough, and they're going to need replacement.
        • DOE
          • Mar 2010
          • 258
          Have you ever replaced belts on that finisher. I know some of them are Not to easy to replace on certain finishers
