C250i going offline and noisy
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C250i going offline and noisy
    Uncheck snmp under port settings for the offline problem
    I was going to try this today, but the fricken customer restarted the machine before we got there.
    Have you tried this on a machine that was presently "offline" according to windows? SNMP was the first thing i thought of but never got to try it.
    Note: I am refering to port settings at windows driver, if you only disable SNMP at the mfd and leave it enabled at windows printer driver port settings this will result in a machine permanently offline according to windows.
      • 29431
      This is a known problem windows broke this years ago, if printer gets any error windows disables driver, when the error was fixed it would send a signal back to driver THATS the part Windows BROKE, You don't need to turn off at copier just in the driver. Uncheck snmp under ports on every driver.
      • Bix
        • Apr 2018
        • 1421
        This is not a driver problem.
        I've already tried to disable SNMP and two-way communication without success.
        Every morning the printer goes offline. But beware: scan to email, CSRC, etc. also goes offline
        So the problem is really the machine. It only happens to me with C250i and I think it's a firmware bug. For the moment I have solved this:
        1. CE Mode> Sleep on / off: permit.
        2. Administrator> Power> Pause mode: no.
        3. Enable energy saving: normal.
        4. Power consumption in pause mode: Active.
        After I went to the timer, I set it to "Pause" instead of ErP and I later turned off the weekly timer (in the past there was a bug in some firmware).
        • BHM
          • Feb 2011
          • 126
          #19
          We have about 15 to 20 of this model out and no issues. They do have the latest firmware. I forgot the version number but it is the one that enables the Airprint opition. We are in the US.
          • Bix
            • Apr 2018
            • 1421
            #20
            In Europe we have version 45 as the last firmware.
            I had the problem in 3B and 45.
            For the moment, the deactivation of the timer and suspension has solved the problem. The network card does not freeze.
            • occus
              • 323
              #21
              Now i have the same problem on a +250i.
              Customer cannot print when the machine goes offline, to bring it back online, they cycle the power OFF/ON to the copier.
              Like on the first days of the e series, i have deaktivated the deep standby
              ...the label energy star says hello and the fuser earlyer goodby... nothing new from KM.
              I don't understand why this is not fixed in the newer generations.
              • Toxic
                • 694
                #22
                I have some note for settings on C224e with same problem years ago.
                Maybe you could try on 250i
                System 1 -> Sleep ON/OFF Choice Setting Permit
                Admin mode
                Sleep Mode Settings Off
                Power Save Settings Low Power
                Power Key Setting Sub Power Off
                Enter Power Save Mode Normal
                • Bix
                  • Apr 2018
                  • 1421
                  #23
                  Hi, the only solution for me was to disable all the options in "Weekly timer". I think the bug is in there.
                  For several days the C250i seems to go without problems
                  • occus
                    • 323
                    #24
                    Not in my case... i deactivate this function on all devices in initial setup.
                    • Bix
                      • Apr 2018
                      • 1421
                      #25
                      On which firmware version?
                      edit -
                      I currently use 45. Disconnect the plug and the ethernet completely. Turn ON the MFP and then plug in the network cable.
                      Another thing that I have disabled is the IP Filtering which by default is ON.
                      • occus
                        • 323
                        #26
                        Firmware 45.
                        At the moment the problem is solved with disabled Sleep function. I have to wait now to see what happens.
                        But thank you for your advice.
                        • Bix
                          • Apr 2018
                          • 1421
                          #27
                          There appears to be a new firmware: G00-73
                          However, in the logs I don't see the resolution of this strange problem mentioned
                          • srvctec
                            Former KM Senior Tech
                            • Oct 2009
                            • 827
                            #28
                            Just checked and not available here in the US yet.
                            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                            • occus
                              • 323
                              #29
                              Same Problem with the Firmware G00-73, sometime it goes not down and comes not up. There is no fix for the standby problem.
                              Energystar byebye with the deactivated settings.
                              And now i have to visit a noisi 250i...
                              • bugzy
                                • Jun 2011
                                • 3
                                #30
                                Replace the storage board, I have done this on 2 machines and it has worked
