C250i going offline and noisy
  • Blobber2
    • Dec 2017
    • 2
    #46
    Re: C250i going offline and noisy
    Originally posted by occus
    Here the noisi 250i from a good customer with mobile camera.
    It was with the Firmware G00-45.
    There was no printjobs at the moment of the nois, no jobs are involved, and not after a power on. It happens in ready state in not regular intervals.
    It sounds like a fan or hardware but i hope it was the fix in the firmware G00-73. The noise are localized from the customer near the Fuser or under the panel and there is a speaker.
    2.3. Fixed issues
    1. Abnormal noise may be heard from the speaker after the main power ON.
    Hello,
    Did this noise reoccur? I am having a very similar noise on the same machine. Customer reports it happening but have not been on site while it has happened. They showed me a recording and it sounded like that.
    • Bix
      • Apr 2018
      • 1421
      #47
      Unfortunately, after several days, even today c250i offline! Even with the suggested energy saving settings and after clearing all.
      Turned off and on again, it started working again.
      • occus
        • 317
        #48
        Originally posted by Blobber2
        Hello,
        No, i have no customer feedback/call until today.
        • Bix
          • Apr 2018
          • 1421
          #49
          the G00-75 has come out, no timeout information or energy saving problems in the logs. But something has changed in the CPU.
          • Blobber2
            • Dec 2017
            • 2
            #50
            The intermittent noise my customer was having has also not happened since the new firmware.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              #51
              With the noise - do you have the bluetooth option installed in this machine, that adds the additional speaker?
              I've had several of these dead out of the box or within 5 minutes of first power on making this stupid noise.
              Solution ? unplug the speaker. It's only used for the voice license that literally no one ever purchases.
              • tsbservice
                Field tech
                • 7916
                #52
                I was able to catch our office C250i going offline plus it was completely frozen and can't awake in any way I tried. Restart from main power switch cure it.
                That weird machine has every new FW KM made installed in a few days and still acting strange from times to times. If machine was in picky customer's office I would be driven mad.
                Today I update it with latest and greatest GC1-75 FW, we will see but I'm not a believer.
                • Bix
                  • Apr 2018
                  • 1421
                  #53
                  The good thing is that with the grounding cable on the back of the screen it finally goes into standby. But after several weeks, it never woke up from standby and went offline. Firmware: G00-75
                  I don't know if GC1-75 solves, no note about it! Other C250i that I have recently installed have not yet given me offline problems. it is as if there was something wrong with the first C250i launched on the market.
                  Every time I contact KM they say I'm the only one who has the C250i problem that goes offline but from the testimonials I read here, it doesn't seem to be like that.
                  • occus
                    • 317
                    #54
                    I had this on the first +250i but after the slepp mode is disabled in my case the problem is solved. Maybe you can run the machine in 100% ready state for a while 24-48hours to check if its happen again, or switch the machine.
                    solved problems:
                    -goes offline
                    -noise from speaker
                    awakening/boot up in ready state without a interacation >> i think this is solved but not sure from firmware or grounding wire. Until now i have no feedback.
                    open problems not on all machines:
                    -complety different print colors on different machines (out of the box with same settings and gradation)
                    -custom size from bypass, the size automatic meausurement(new on i+250) does not work, it shows always full lenght 42.xx cm. But i found a mask to put in the size manual like the older series.
                    -auto rotate from bypass portrait and landscape does not work, ask alwasy for portrait. Windows10 different application
                    -1 machine have lost date time settings installation date tel number... hello lines on the copy
                    I've heard of problems with ssd's but I'm not affected myself
                    I've heard of problems with ssd but I'm not affected mysel
                    • Bix
                      • Apr 2018
                      • 1421
                      #55
                      Yes, previously someone wrote that replacing the SSD has solved problems with the offline. But honestly, I don't understand the relationship with the problem, if it ever works.
                      • Bix
                        • Apr 2018
                        • 1421
                        #56
                        I'm not convinced GC1-75, today on a machine I had a completely white screen for the first time. To reactivate the MFP, I had to turn it off and on again.
                        • occus
                          • 317
                          #57
                          Maybe thats the reason why they removed the GC1-75 from KNOVA. I can't found this version anymore.
                          • occus
                            • 317
                            #58
                            Hello Bix
                            Now the first delivered 250i comes back with offline problems...
                            Have you found a solution until today?
                            I am not sure whether it comes from the firmware GC1-75 or was just luck.
                            I am not sure whether it comes from the firmware or was just luckI am not sure whether it comes from the firmware or was just luck
                            • Bix
                              • Apr 2018
                              • 1421
                              #59
                              Hello Bix
                              Hi occus,
                              I have a couple of theories in mind about this problem. To be honest, I'm not sure if the problem is solved but for now the MFP is not giving problems.
                              I am still unsure why sometimes a few weeks passed before the problem happened.
                              Now my C250i has firmware GC1-75. Here's what I did:
                              1. Fixed problem of MFP not sleeping. Do this too, if you notice that the MFP wakes up from standby for no reason, there is a problem with the grounding: Awakening from causal energy savings
                              Inside the C250i a strange static electricity is created which, in my opinion, could send some electronic boards in tilt. But then again, I'm not sure about this.
                              2. I set instead "turn off secondary power", I set "energy saving" and instead of "high" I set "turn off".
                              3. I noticed that in the parts code, the SSD code has changed. Here someone suggested replacing it and this solved the problem. For safety I have changed that too.
                              If all this doesn't solve my problem, my only doubt is a defective BASE BOARD. In the parts code I have not noticed any new code but it is strange that in the recent c250i that I am installing, this problem does not occur.
                              At the moment, if I contact KM, they say they have not received reports of this problem. The only reports were resolved by disabling SNMP from the driver settings, which I have already done.
                              • Bix
                                • Apr 2018
                                • 1421
                                #60
                                Today a C250i that I thought I had fixed for the offline issue went offline again.
                                I believe that the screen generates static electricity (it causes the printer to inadvertently wake up) which reaches the BASE BOARD and therefore freezes the printer after a few days/hours. I have seen that Konica Minolta has finally put a parts code to discharge this static electricity.
                                part code: 9981001424
