My first c250i squeak
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    on a brand new machine out the box the waste toner transport unit (removable) was squeaking -
    The bottom transport auger has no lubrication at its end support and its a dry plastic on plastic squeak anytme the drums / belts is running.
    Possibly might go away once it fills with waste toner and that itself lubricates / grinds the end of the auger but till then it would likley cause a complaint.
    On an empty one it was a relaitively easy fix, except for the billion screws to open and care must be taken or it falls to bits on disassembly. Wont be pleasant in the field once its full of waste toner. I'd consider just replacing it if possible.
