Konica 7040 error
  • hekotez
    • Jan 2007
    • 91
    Konica 7040 error
    Hello all,
    I have a konica 7040 that is presenting error F-36-2, i belive it has to do with Fusing Unit temperature Sensor, can anyone please confirm this?
    And is it necessary to do any kind of reset at this error code? If so, how can i do it?
    Thanks for any help in advance.
  • Mark B
    • Jul 2006
    • 153
    Fuser code. 25 mode bit 3 they should all be zeros
    • hekotez
      • Jan 2007
      • 91
      I am not familiar with Konicas so could you please explain a bit more how to operate the keyboard to enter service mode and enter those values?
      Thanks in advance.
      • CMB
        KonicaMinolta Tech.
        • Mar 2005
        • 458
        turn copier on in the 25 mode.
        http://christianoutdoorsman.com/forums/
        www.lewisdigital.net
        Lewis Digital
        630-1 Capital Circle N.E. | Tallahassee, FL 32301
        Telephone: 850.222.4418
        Live such good lives among the pagans that, though they accuse you of doing wrong, they may see your good deeds and glorify God on the day he visits us. 1 Peter 2:12
        • Mark B
          • Jul 2006
          • 153
          Sounds like an end user!
          • skirt_chaser
            Sounds like an honest question.....
            Here's the details...
            With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03).
            Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
            There are three power-on service modes such as this, they are:
            4+7, 2+5, 3+6.
            We call them 47 mode, 25 mode, and 36 mode.
            Cheers.
            • CMB
              KonicaMinolta Tech.
              • Mar 2005
              • 458
              you may want to check that fuser out real good before you reset any codes. it may be a fire hazard. that code came up for a reason.
              Lewis Digital
              • skirt_chaser
                Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too. I did it by taking out the fuser ass'y without powering off the machine - doh ! Busy, busy, haste makes waste.
                • Dr.silver
                  • 38
                  Does this work as well with the Konica 7033 error code f-36-2?
                  • mrwho
                    Major Asshole!
                    • 4303
                    Those two machines are basically the same, only with different speeds, so yes.
                    Mascan42
                    Ibid
                    • Dr.silver
                      • 38
                      Thank you very much.
