B42 replace toner message
  • Brett GS
    • Jun 2013
    • 154
    Hi all
    Got a B42 that gives the message "replace toner" even thou the gauge/bars show full and the bottle is full.
    So fare replaced developer,hopper and toner bottle drive assy.
    Anythinge else i am missing?
    Sub hopper or printer controll board may be?
  • Rohullah
    • Sep 2019
    • 37
    Re: B42 replace toner message
    Originally posted by Brett GS
    Hi all
    I dont know about this printer but i had same issue in c8000 and problem was from toner holder cover.it was very tight and toner not move easily.
    Open toner supply door
    Lose the toner holder, active door sensor by some screw, push the toner by your hand and keep your hand back of toner, and start machine, see toner is moving or not, if moving, wait for a while untill stopped. Than error will gone.
      you replaced all those parts...
      did you ever run SENSOR test in SM?
      did you CLEAN the sensors? replaced?
      you give little info in this subject..
      how about LIFE on PARTS?
      Total Counts?
      OEM genuine supplies or 3rd party?
      are you a tech or end user?
      • Brett GS
        • Jun 2013
        • 154
        Total Counts?
        Im a tech,all OEM.
        Replaced the sub hopper again from a donar machine and all sorted now.
