BIZHUB C35 13E2
  • sakisvas
    • Nov 2016
    • 33
    BIZHUB C35 13E2
    Dear friends ,
    my customer has a bizhub c35, the problem is tha the machine work fine as printer but when i go to copy the machine freez ..
    In the control panel write ready for copy ... calibrating.
    i try to update firmware and when i reboot the machine the error code : 13E2
    what can i do.
    best regards
  • tsbservice
    Field tech
    • 8081
    Re: BIZHUB C35 13E2
    1. Try to rewrite engine firmware.
    2. Replace PRCB.
    • sakisvas
      • Nov 2016
      • 33
      Re: BIZHUB C35 13E2
      2. Replace PRCB.
      can you send me please a firmware for update with usb please?
      i have this file : bizhub_C35_EngineFW_v50G0-0200-00.zip
      it is correct for usb update ?
      • rrrohan
        • Sep 2011
        • 1977
        Re: BIZHUB C35 13E2
        the standard expectation before anyone will supply firmware or manuals is that you donate to the forum
        https://www.copytechnet.com/forums/v....php?do=donate
        once you do you will get a Contributor badge under your name, im sure once you do that we can hook you up
        • sakisvas
          • Nov 2016
          • 33
          Re: BIZHUB C35 13E2
          can anyone help me with the firmware?
          thanks
            • 15069
            Re: BIZHUB C35 13E2
            Just had this issue yesterday. There are two engine firmware versions based on the PRCB. One version has a 0 and one version has a 1. One version is 50G1 and the other is 50G0. If you use the wrong version you will get a 13E2 code.
