Error on startup, anyone with similar problem?
Bizhub pro 920 SC 46-01 error
Re: Bizhub pro 920 SC 46-01 error
SC 46-01 is indicated. Solution: PROBABLE CAUSES: This code is triggered by the lack of 12VDC being supplied to the print head. Please check the following: Check for 12VDC at the Image of cleaning Very HighVoltage Drum Charge Wires and Image Transfer and seperation High Voltage wire The wires have a corona form on them and need to be cleaned
Sent from my RNE-L22 using Tapatalk
