Bizhub C454e Won't Print PDF files
  • integritybob
    • 67
    I have a Bizhub C454e that won't print pdf files. When a job is sent to the printer the blue lights on the front start blinking, the fan comes up . . . and that's it. Nothing shows up in the job list. From the computer, first it says "printing" and then that a printing error has occurred. The unit just sits there with the blue lights flashing.
    Copying and scanning (email and FTP) work fine. Small print jobs, such as a text file from Notepad or an email print just fine. PDF's, regardless of size, will not print. This is not a new installation - it had previously been working fine.
    I connected directly to my laptop with a crossover cable and installed both the PCL and Postscript drivers, The unit was detected during driver installation and both drivers installed normally. The driver test print will not print from either driver, but again, I can print a text file from Notepad or a web page from Chrome.
    The system is in a law office with Account Tracking (password only) configured. The password popup shows up as expected. Again, small files (other than pdf) print normally.
    I ran all the onboard diagnostics for memory, hard drive, etc. and all came up OK.
    Thanks in advance for any suggestions.
    Re: Bizhub C454e Won't Print PDF files
    I would go thru the print driver setting ... try "print as image"
    also you might try PS driver but more like the above solution will fix it for you
    • integritybob
      • 67
      Thanks for the tip. Unfortunately, I've tried "print as image" as well as the PS driver with no luck. I also tried turning spooling off.
      • copyrooks
        • Oct 2013
        • 208
        is the customer using adobe reader to print? if they are, i'd try a different program like sumatra pdf to see if adobe could be the issue.
        • integritybob
          • 67
          Thanks for the tip. The customer is using Adobe but I have Sumatra on my laptop - no joy. I also tried printing a pdf from Chrome with no success.
          • tsbservice
            Field tech
            • 7951
            Did you try to print PDF file from USB thumb drive? That may rule out machine part if successful.
              might help if you mention such things in the OP .. but ok.. lemme think.. anything else we should rule out?
              • tsbservice
                Field tech
                • 7951
                Also comes to mind using direct print PDFs through web connection avoiding print drivers.
                Last resort may be to Initialize machine though.
                Let us know how it goes.
                • kirin
                  • Mar 2008
                  • 7
                  Hi, review "image controller setting" in "System 2" , default is "controller 0"...maybe
                  • integritybob
                    • 67
                    Thanks for all the suggestions. My apologies for leaving out pertinent information - I was short on time when I composed the original post.
                    Here is a little more info: I can access the web connection in a browser and print out the demo page, font lists etc. with no problem. I haven't yet tried printing from a thumb drive.
                    Also, sometimes after a printing failure the unit will print out a sheet with the following cryptic message in the upper left corner:
                    PCL XL error
                    Error: ExtraData
                    Operator: ReadImage
                    Position: 160
                    That's when using the PCL driver. Sometimes it also happens with the PS driver, with a different message:
                    ERROR: ioerror
                    OFFENDING COMMAND: image
                    STACK:
                    I will be returning to the customer tomorrow morning and will post an update.
                    • tsbservice
                      Field tech
                      • 7951
                      PCL XL error
                      Error: ExtraData
                      Operator: ReadImage
                      Position: 160
                      ERROR: ioerror
                      STACK:
                      Then can be wrong Image Controller Setting, maybe after somebody did Clear All Data.
                      • emujo2
                        • Mar 2017
                        • 1580
                        Those messages are spit out when the RIP does not understand what is being sent. It may be a simple PDF that your Windows 10 laptop can read just fine, but the C454e just can't understand what it is, could be an image file or even a font..FYI--Win10 drivers are version 5.1.2.0, and the matching firmware is G20-M1/function ver 7.. If you are using any different combo I would update ASAP. This does not mean there is not a problem with the machine..It's near end of life..What does service mode report for CE301, FA14 ect..E
                        • integritybob
                          • 67
                          Update:
                          Still no success.
                          Image controller setting is "Controller 0".
                          Some documents will print from a thumb drive - some will not. There doesn't seem to be any pattern - some relatively large pdf files print fine while a single page b&w document will fail. Even some scans from another bizhub would not print. Jpegs seem to print okay, at least the few I tried.
                          The system has a fax module and incoming faxes seem to print okay.
                          Logs show a single C-E301 and a couple of D353 a month and a half ago (when the system was printing just fine).
                          Another error printout after attempting a relatively small pdf with the PCL driver:
                          PCL XL error
                          Error: InsufficientMemory
                          Operator: ReadImage
                          Position: 19
                          Firmware is G00-K2. I'll update it when I go back. Print drivers are the most recent.
                          • tsbservice
                            Field tech
                            • 7951
                            If not run full diagnostic to check for any NG result. Other that that I would do Clear all data as to me it looks you have some corrupted data.
                            • copyrooks
                              • Oct 2013
                              • 208
                              Might be a long shot but, Check the network speed option on the copier and see if there is any improvement. I had a customer's IT dept manually set the network speed on the copier and would always get complaints from slow printing til i set it on auto and worked great after.
