C-D010 on two different machines- customers own machine and our loan machine !
  • patk
    • Jun 2008
    • 56
    We have a strange problem at a customers site.
    Bizhub C458 had been fine on customers network until machine was nearly two years old. Then C-D010 appears on machine, machine locks out and can only be recovered by reformatting HDD. After this all is fine for 3-4 weeks and then occurs again. This time HDD is replaced.
    5 weeks go by and problem recurs. HDD replaced again, 2 weeks later C-D010 code again.
    KM suggest PWB-MFP. So we take machine out of customer and install Bizhub C-554e on loan.
    We test the C458 on our own network - after 2 weeks C-D010 code occurs. We think must be PWB-MFP as suggested but have not fitted yet.
    BUT.........
    After 3 weeks at customers, Bizhub C554e loaner now has the C-D010 code on it ( Loan machine has never had C-D010 previously, ever)
    Has anyone got any idea what the problem could be ?
    Cheers
    Pat
  • pajeroid
    • Jul 2009
    • 130
    Re: C-D010 on two different machines- customers own machine and our loan machine !
    Have you loaded the latest firmware? That has a fix for this SSD related code. If not, change the SSD and follow MFP replacement guide.
    • nelo
      • Apr 2019
      • 32
      I had the same issue and was fixed by uploading the firmware fix for this particular error code. This firmware contains the bug fix for SATA controller. The machine was a Bizhub C658.
      The cause for the machine displaying error C-D010 issue was power surge related. I had the machine hooked on UPS with power surge protector, customer had to supply this.
      Regards
      • patk
        • Jun 2008
        • 56
        Thanks for the replies
        I have not been able to find any reference to C-D010 in the latest firmware read me. I have also not been able to find the special sata firmware for the C458, only for the smaller 8 series machines.
        Can anyone point me in the right direction
        Cheers
        Pat
        • gere1
          • Oct 2018
          • 20
          try doing first
          physical format
          and after restarting the
          logical format
          so I have recovered some of the series 4
